whats the best place to get a sub box from make one or buy one its a db audio sub think its the DB Audio T-Rex model
i can prob make one but it would be simular to a normal box u can pick up for 20 i duno how to figure the size and stuff thou my boot in the lupo is tiny too whats the differnece between ported and sealed box's cheers
the charactoristics of the sound produced, a sealed box gives a quicker more punchy sound, a ported box will be slower and drop lower, what sort of music do you listen to? tim
true, but then it gets complex, he isnt after a top quality set up, best to just keep it simple imo, tim
this is the sub 750W 10" Dual Voice Coil Subwoofer 375W RMS Textured Injection Molded Poly Cone 2" 4 Layer KAPTON Voice Coil Custom CONEX spider Chrome basket Platinum spring release post terminals magnet size 9"1/4' wide magnet size 5"1/4' Recommend enclosure: Seal: 0.6 cu.ft @ 54Hz, 1.1 cu.ft @ 46Hz Vented: 1.2 cu.ft @ 35 Hz
is that quite a good spec for a little 10" sub? found these on ebay about 15-30 for a box already made ebay link what power amp would be better for the sub and mabey to power some components too
TBH you might aswell buy one! Make sure it is made out of 18mm MDF. If you're gonna make one it's gonna cost at least 15 including MDF/vinyl/carpet. Oh and there's the time involved. For 20 I'd just get a sealed one that is to teh above specs.
