Does anyone know where I can buy some of these 12 point tripple square bits to remove suppension from a mk4/mk5 golf Or are they called something else ? Cheers Craig
If they're the same sort of size as the ones for the driveshafts on my 16v then i got mine from halfords. Think they were part of a set of 'specialist' bits.
http://motors.search.ebay.co.uk/spline_Garage-Equipment-Tools_W0QQ_trksidZm37QQcatrefZC12QQfromZR40QQsacatZ30896
XZN Spline Bits... For example... http://www.teng.co.uk/product-details.asp?prod_id=3226 or http://www.chrometrader.co.uk/ViewProdDetails.asp?prod_code=12769&Prod_name=XZN BIT & HOLDER SET 5PC. Not sure if they have the size you need though
it is for the bottom bolt I think your right, I just tried the biggest tool I had M12 and it was no where near big enough Where can i get a m14 bit from? Cheers
It might work, but the T is a Torx and the XZN drivers aren't the same. Torx are 6-points, and XZN are 12-points (aka triple-squares). Broke
If it is to remove the wheelbearings/hub unit then it is a M14. The vag tool is T10162. You might need a stepdown from 3/4 to a 1/2 inch as the tool comes only in 3/4. cheers paul
I have a teng set with them on cost me an arm and a leg though. I try and avoid halfords after cracking a 13mm socket whilst undoing the 3 bolts that hold the balljoint on
Spot on its a M14 "spline tool" I got some from halfords they go upto M16 20 for 7 bits 16 with discount Cheers all
I just grip the head with vice grips and undo the nut on the other side. You should be turning the nut anyway, not the whole bolt.
