Hi good people Can I run a pair of 288 cams on my 16v turbo only asking is I have a solid lifter head with them cams in, bottom end is 9.3 compression Thanks Nas
288 inlet cam can be used in combination with a std ABF exhaust camshaft ( ca 260 ) Set cam timing @ ca 120 exhaust and inlet @ ca 110 With a larger turbo you can use longer duration exhaust like 276 or 288 cam to get more overlap and spool the turbo that way and you can play with cam timing
