A bit of of a dumb question... I'm trying to remove the fuel lines, the underfloor fuel line clips are really tight and trying to prise the clips apart just makes the top lip of the clip to overlap and dig into the top of the fuel line. I don't want to bully them out as it looks like the lines would be damaged. Is there a technique or a way to remove the lines from the clips without damaging the lines? Cheers.
I inserted a wide based flat & thin screwdriver between the fuel line and clips to prise them out whilst pulling gently on the line - just be careful you don't knick the fuel line.
