Hi there, have you any experience with building 16vg60 engines? I have a kr block which I would like to take to 1.9 litres and then fit suitable pistons to lower the compression ratio. Im looking for advice on the best pistons to go for and if the kr block is the best block to base the build around, thanks.
Hello you can really use whatever block you want, but a kr is probably easiest you can then just build a 16v motor with a suitable comp ratio for supercharged.
