thanks more new things New jets, now running like swiss watch old jets and blue-ish side mirrors already installed I was never good with puzzle game :/ finally after a while I have figured out how it's supposed to look
welded intake manifold on the engine this was first start with old nozzle's, back then i had lot of problems to fix.. http://www.youtube.com/watch?v=_DAWs-al3MM engine config back then: block: Short ''9a'' renewed cylinders, new pistons(stock) new mahle piston rings, lightened flywheel etc... head: ''9a'' head, 10.5:1 CR, ABF cams, new valve guides, new valves.. etc... exhaust: ABF tubular exhaust manifold, 55mm catless exhaust with one resonator without rear muffler intake: euro mk2 golf's intake manifold with 30mm shortened runners and upper chamber from scirocco 40mm intake, attached to 50mm lower intake manifold, custom CAI. hope you like it
here's some progress front minus bodykit and hood new OEM looking exhaust OZ Superleggera 7x15'' Hankook V12 EVO 195/50R15 tires on the car with stock suspension (Gravity off )
I'm currently thinking of trying to make car handle better, so I'm trying to find some caster/camber plates that will fit on it and i'm thinking of buying H&R twin tube coilovers for 600€ with damping andjustment. does anyone have any suggestions for nice suspension setup that will handle, and will be comfort to drive?
Superleggeras were sold, so I have bought 16'' BBS RX 226 from mk4 that easily fit over 312mm front brakes that are already fitted bought 195 45 16 Toyo T1R for rimz... New front hubs redrilled 4x100 M12 i 5x100 M14x1.5 threads New FAG bearings(front) Adapter fur 312mm bremse Redrilled rear discs 4x100 M12 i 5x100 M14x1.5 threads rear brake lines put wheels over new brakes missing thread was fixed with screw that i can fit newer o2J cable holder finally got 02J cable shifter holder
well some updates bought few things to make my build better ... tdi's oil pan gasket newer mk4 o2j shifter installed older reverse gear switch to clear gearbox bracket and got into problems that are still unsolved.. fckin ebay rear 02A gearbox bracket that doesn't fit! wheels/tires/brakes (front) stupid rear gearbox mount again then i have decidet to use my frankenstein intake and had to make some things fit onto it IAT sensor hole IAT sensor on it's place with little adapter made some pipes that i can get some fuel onto injectors from 20vt manifold fuel rail holder complete intake with fuel rail then i have had problems with FPR that was problem for hood and made fuel rail little different
continued bought this from vw coleague got apexi turbotimer my mate ordered some things for me... oem newer 02j shortshift(right one) and fabia rs stainless pedal covers to be continued!
glad you like it intake is there to have little less torque and little more hp, and to clear some room for wastegate
