2E 2 litre to 2.1 litre
Discussion in '8-valve' started by G60Dub, Jan 23, 2004.
  1. G60Dub
    G60Dub Forum Member
    Angus
    Hi fellow car fiddlers,
    I'll be removing my cylinder head in the next couple or three months (to up the valve sizes) and was toying with the idea rebuilding the bottom end in 2.1 form. I guess that you use the 95.5mm diesel throw crank and some new pistons. I have a couple of question about this - I guess the extra throw will reduce the revability even with big valves so is it worth it? Piston wise I don't have a clue what to use - Do I have to purchase new pistons or can I source appropriate pistons from another engine. Anyone any idea what the diff (pwr and tq wisae) would be between a BVH 2.0 and BVH 2.1?
  2. chrismc Forum Junkie
    Ive been advised to steer clear of 95.5mm cranks.
    The engine just won't rev out at all..
    Stay 2L. The Big Valve head makes a world of difference especially with a lightened flywheel & 276-280 deg cam!!.
    My car makes it maximum power at 5700-5800, with a 92.8mm crank, so I would guess a 2.1 would be lower than this [:^(]
  3. G60Dub
    G60Dub Forum Member
    Angus
    Cheers Chris; I thought as much as I'd heard people say that it wasnt worth the hastle or expense. I just don't want to go thru the hastle of discovering there was something else that I could have done when the bottom end is done. I felt such a twit when I discovered that I should have fitted big exhaust valves and I can still remember being at the engine builders and thinking nah surely it wont make that much difference (capital TW*T! [:$] ).
    Big valves and a lighten and balance it is then.
    That's a beautiful MKII BTW!
  4. Fozzie_Bear Forum Member
    Bosnia Hercegovina
    Got to disagree here. My mate is running a 2.1 16v (diesel crank 95.5mm stroke) with 296 cams and 48 dellortos, and belive me it revs VERY well indeed!!
    All I can suggest is that if your gonna go down that route, get the crank and flywheel lightened and balanced. The crank is alot heavier than a standard one, so removing some weight will help it rev up.
    Couple this with some nice cams and it'll go well enough.
    As an example Morreuce Reeves(spelling) regularly used to use these a few moons back, built by John Jones. So if its good enough for him to use around Combe then who am I to argue.
  5. Southy_GTI Forum Member
    Turkmenistan
    One major point of contention there Fozzie - 8 more valves.
  6. g60 pb Forum Member
    I thought that too...my maths is gettin better ;)
    Wokka Wokka Wokka.....
  7. chrismc Forum Junkie
    I agree with Southy. The 8 Valve, be it with Big Valves or not does not have anything like the valve area of a 16v engine. This is why a 16v will rev to 7200 as standard and an 8v 6500.
    Those 2.1 16v engines are running very lumpy cams & breathing thru 48s to allow them to rev..
    An 8v just wont do it. Maybe with a crossflow head, silly cam & throttle bodies, but thats a different story! ;)
    Edited by: chrismc
  8. Fozzie_Bear Forum Member
    Bosnia Hercegovina
    My fault there lads, didn't read it all....doh!
    Yeah the 8v ain't gonna breathe enough for it really so won't rev as well.
    Think I'll get me coat [:s]
  9. Southy_GTI Forum Member
    Turkmenistan
  10. Jon Olds Forum Junkie
    Any ideas on part nos. for the diesel crank? Or model/year. I'm running a hi-spec 2L16V and am always after the next upgrade. Thanks.
  11. fthaimike Forum Addict
    8v not rev......mine revs extremely fast but then again iv'e done everything i can to mine. (16v's are SO slow :lol: ).
  12. Fozzie_Bear Forum Member
    Bosnia Hercegovina
    Wished you'd have asked about the crank number a few months ago. I'd just built one using a diesel crank.
    Have to watch out for clearence inside the casing, I found the crak was just touching the bolts for the oil squiters in mine.
  13. JEZ
    Jez Forum Member
    TSR advertise their 2.1 16v as being limited to 6500rpm due to the longer stroke....
  14. Jon Olds Forum Junkie
    If its a genuine VAG part, then I'd be ok taking it higher than 6500. Prob 7500. Are the mains and b/end journals the same diameter? Is the crank nose and tail the same as an 18/2L?
