hi guys, quick question .... looking to make some changes to try a few things, basically i wanna know will i have enough room on a standard 2e engine to fit 48 DCOEs in the engine bay on my mk3??? how tight will it be ???? otherwise x-flow head it will have to be ...... cheers
48's on a 2E might be overkill. You'll probably have to choke them down quite a bit unless you have a spec list the length of your arm. 48's are also more expensive than 40's/45's. As for space, not alot although definatly possible and has been done on quite a few cars. Main issue is heat from the exhaust manifold.
