Anyone know if the polo 6N and 6N2 stub axle bolt hole configuration is the same? Have been sent a drum and bearing kit for a 6N but it doesnt fit over the stub axle as I have a 6N2 - in an attempt to get the daily running this weekend I was wondering if the 6N polo stub axles fit? Cheers
i think it's different bolt patern but i could be wrong you could measure it the picture below is of a polo 6n stub axle sizes
had a look at this and they should in theory swap over but thats not to say there will be no pit falls
Thanks for the pic and sizes! Decided on the back of this to try it out yesterday - picked up a set of stub axles from a scrappy 6N polo and they were a straight swap - Cheers! The full 6N2 setup is about 200 while the 6N kit (even with the stub axles) came in just under 100 so easy way to make a bit of a saving. Could only find one place that sells the 6N2 bearings as well. Only problem was I damaged one of the abs sensors while removing it from the axle's backing plate!
