Can someone confirm if the small bit of rub strip from the front wing is part of the front arch or seperate? Thank you.
Cheers Luke. Next question. Is there any preference for quality between ECP and GSF pattern parts? May as well get some G60 arches if I'm having to replace one anyway.
Just my personal opinion but if you've still got "normal" width wheels g60 arches won't look right, you'd need to space the wheels out to match. I bought all my standard gti arches from gsf recently and can't complain with the fit or look of them. All i would say is inspect them well before you buy and take them away, as some of the ones i was given first time around were shoddy quality...looked like they'd been dumped in a corner for a while and got all scratched up..sometimes gsf are a bit crap like that.
I used to be the same! Always assume you're being given top quality stuff when you buy brand new...after a while of using gsf you soon learn to check first though!
as it happens ive got a set of 90 spec arches and skirts i'll be looking to shift if you're interested in those instead
