Hi All, I’m 90% sure the following set up will work but as always there is some conflicting information out there so wanted to make sure. I have… ABF engine, ABF flywheel (part 037 105 273 C), an 02A gearbox. I was looking at getting a VR6 clutch (641440660 from ECP) if this would work? The bit I am most unsure of is the starter motor… I have 02A-911-023/L from Heritage, would this work or would I need a VR6 starter? If not could I change to an ABF clutch (641440450 from ECP) to make that starter fit? Thanks, Dan
