2 pin with yellows, dimdip resistor. can keep or bin, it puts dipped beam on dim with sidelights. not required by law or for mot outside temp sensor is for your MFA, keep it if you want this to work or bin if not brake fluid wires keep if you want the light to go on if you have low brake fluid, bin if not bothered dont worry too much about wire colours on the MK4 loom, they can differ. Concentrate on pin positions. the pinout of green and white plugs are the same, just early cars had green and late had white. if you're lookign at my oem guide on a phone or tablet, try it on a PC instead or at least something with a bigger screen, and look at it in landscape mode. if you have a phone on portrait mode you often loose most of the tables
Cheers for that... Wot advice can you give for exhaust and cat wots bits can I use as are make one up
trackslag and william skelton off FB offer off the shelf mk2/3 20v downpipes, see what they have to offer you
Not paying them prices a rather make one I've got bits and bobs just wondering wot cat wud work and down pipe off a mk4 20v and a3 20v
no you need both the front and rear abf/tdi mounts plus abf/tdi/vr6 gearbox mount. the rear bracket is 10mm longer, but you could just fit 10mm spacers between bracket and block if you only have front and box brackets
Strange my agg mount is exactly the same as a tdi one size shape and I know its from a tdi because I removed it today from my old tdi mk3 Estate
