All possible 2l 8v mods to get the most out of it!
Discussion in '8-valve' started by fly, Mar 16, 2008.
  1. FLY
    fly Forum Member
    Hey, I'm looking at buying a 2l 8v conversion of someone i know. i know it has the following-
    -Vento bottom end
    -4 branch ashley manifold
    -Full magnex system
    -Piper cam
    -Lightened fly wheel
    - pipercross induction kit
    -Harder aftermarket engine mounts
    -Some mention of adt fuel system but to be honest not sure what it is exactly!?
    Just short of 160bhp but what could be done for a few more ponies!?!?
    Thanks,
    Aaron
  2. Dicky Retardo Forum Member
    Wokingham
    would not of thought you would get 160bhp without headwork!?
  3. FLY
    fly Forum Member
    ahh, i have a feeling its ported and polished too woops...
  4. xrr319y Forum Member
    16v warm up reg and the large ?2.2? or 2.5?? audi throttle body cant remember what model its of though..
    thats if its on kjet for the 16v wur
  5. fthaimike Forum Addict
    There is a massive thread on here somewhere about 2.0 8v, maybe someone can post it up?
  6. VRSteve Forum Member
    Service Department .... Barnstple
    mount the throttle body on the front of the intake manifold
    like this ...
    my old 2.0 8v producing 180 ish bhp at flywheel
  7. luke w
    luke w Forum Junkie
    Cornwall
    How much money have you got?
    You can go for a cross flow head off a new Beetle (ported and polished with big valves), ITBs, etc.
    Or go forced induction.
  8. fthaimike Forum Addict
    [:s] :o
  9. VRSteve Forum Member
    my god we've been through this before, do i have to put the RR print out up for a 4th time???? [|)] [|)] :lol:
    and please note that wasnt all i had done to it. ;)
  10. Matt82
    Matt82 Forum Addict
    GTI Scene
    that was a kick ass manifold. after seeing yours, i can remember having a look at the next normal one i saw and then thinking 'holy crap a lot of work went into that'
  11. altern8 Forum Junkie
    Cocos (Keeling) Islands
    it would be good to see how it was wit just that funky manifold
  12. Mike_H Forum Addict
    What engine management are you running?
    More fuel pressure is worth doing if it's digifant, or consider a mappable aftermarket system.
    If you want more power, then more compression is the way to go, but it needs to run cool enough and rich enough to avoid pinking.
    That power figure looks a bit optimistic, but it depends on the exact spec - e.g. which cam, what CR?
  13. VRSteve Forum Member
    The head was P+P, gas flowed and skimmed with big valves. kent 285 deg cam + pulley, 4 branch manifold with OMP grp N exh. system, heavily modified inlet manifold with ported throttle body, induction kit and cold air feed, Chipped and mapped ECU, FSE fuel pressure reg
    Fitting just the manifold to a std 2E engine, on the SAME rollers produced 21 bhp.
  14. Mike_H Forum Addict
    Didn't mean your power figure, Steve... I was referring to the bloke who started the thread...
  15. VRSteve Forum Member
    sorry mike :lol:
  16. drunkenalan Paid Member Paid Member
    Leicester
    forgot about that manifold!! surely that would only work with a mk3 head???
    160 from those mods seems a tad optimistic,
  17. VRSteve Forum Member
    Yeh mk4 head is crossflow so ITBS or a manifold similar to a 1.8t would prob be better suited.
  18. Mike_H Forum Addict
    You should start making and selling those manifolds... bound to be worth a few quid - look at the money people spend on exhausts for very doubtful HP gains!!
  19. VRSteve Forum Member
    i did consider it at the time, its such a simple principle where there are absolutely no bottlenecks to 'trap' air so u get everything flowing straight down to the head.
    VRWill used the x-flow head as discussed in previos threads and it needed lots of work to achieve big power.
    i spent less than 1000 on my engine to achive the power i got.
  20. Mike_H Forum Addict
    I don't see why it wouldn't work on a Mk1 or Mk2 manifold, as long as you've got enough clearance under the bonnet.
    Steve - fancy making me one for a scirocco... doesn't even have the problem of the ISV connection!! I have a spare manifold and TB you can chop up!
