looks nice although to be more convincing i would remove the rear section in the glass, and lengthen the doors, the wheels are awesome though
This is a Coupe i have done. I have tried to make it look as factory as possible so i've not added many bits. Evo 8 Coupe On yours i think you need to lengthen the front doors a bit and loose the line in the glass at the rear. The wheels dont look right either. The work you have done the the door line is good though, but you can see a bit on the sill. Edited by: Websnowbo
rear wheels are too deep for the tyres? make the tyres fatter, and loose all the rear door lines you can still see them in the lower part of the wing, and along the sills, tim
Robz, i wasn't hi-jacking i was just showing you that it would look better with the fron doors extended a bit to give a better Coupe look. Oh, and colour wise i would go two tone, as due to the lighting it will work well with a light colour at the top and a dark colour at the bottom. Edited by: Websnowbo
