cool, thanks 2200mbar under full load is a bit low IMO. ive only got a ko3 and mine peaks at that, i was sure ko3ss peaked higher anyway, 115 should show you requested boost VS actual boost and what youre looking for is a difference between the two... ie actual lagging behind requested, which is an indication it is leaking etc
The specified is 920mbar and the actuall is 2200mbar, so the difference is 1280mbar ? Am I doing this rite lol, so this figure is telling me I have a leak as it should be closer to 920 ? Don't fully understand as shown mate
the figures will vary depending on what youre right foot is doing and the revs etc ie 3rd gear, 1200rpm, foot flat, requeted will be practically zero (and zero = 1000mbar, ie atmos) 3kprm foot flat it should be nearly peak, ie 2000mbar++ requested and actual needs to be close to that
I see thanks for running me through this Matt, I got that figure flat out in 2nd gear, so this is pointing out a boost leak, could it be anything else other than that ?
Done block 115 again and all looks well both values are very similar, although not reaching anymore than 2200mbar, could this be a faulty turbo ? Got a missfire count still too, was at 15 at one point lol Block 032 values are still over -5% and -0.8%, boost leak or what ? ( Although block 115 is saying boost pressure is ok ) Unplugged maf and it went an awfull lot better plugged it back in then was really slugish Checked intake temp too which was fine Anyone know of any other blocks i should check ? Cheers
well 2200 is lower than id expect. if its only requesting 2200 then thas the software in the ecu only requesting that. misfire count. whats the state of your plugs, coils and associated loom? misfire = unburned fuel which could be why the ecu has the negative figure on block 032, ie its cutting fuel out to make up for the unbured misfired fuel? and it sounds like new MAF time
Plugs have less than 1000 miles on them and the coils are good that i know of ( had cylinder 2 replaced pecently and anyway of testing them ? ), loom is rather cracked etc but i retaped it up and seems to be fine. Will get plugs torqued and hopefully somesort of brackets made up to hold them down today. Fingers crossed thats this solves that problem. Yeah will get the maf ordered, found a few on ebay cheap and expensive, what would be the best one to go for ? Thanks again your help is much appreciated Matt
can you post actual logs to see? stick Code: and slash [code] either side of it 001 is instant adjustment. usually within the +/- 5% range 032 updates periodically Good ones to log.. 001, 115, 118 to see lambda adjust, bosst request vs actual, and actual boost and n75 duty cycle, aits also... 001, 002,031 to watch fueling AUM engine is wideband controlled so afr's should sort themselves out to a great extent.. leaks causing generally additive fueling adjustments. NOTE: just read the thread again and saw you mention bypass. All the solenoids MUST be connected electrically for the adaptions to work. Are they?
Will have all blocks posted tomorrow around 1 to 2ish so please have a look then Badger5 and yes solenoids are still electrically connected up. Off to work shortly so no time tonight Thanks a bunch guys
Logs All logs were taken at operating temp and at 3000rpm or there abouts Block 001, 002 and 031 first:- Address 01: Engine (06A 906 032 DK) 10:34:23 Group 001: General 3080 /min Engine Speed (G28) 69.0C Coolant Temperature (G62) -1.6 % Lambda Control Bank 1 01101000 Basic Setting Requirements 10:34:23 Group 002: General 3080 /min Engine Speed (G28) 18.8 % Engine Load 2.04 ms Injection Timing 10.97 g/s Mass Air Flow (G70) 10:34:23 Group 031: Lambda Control 0.992 Lambda Control Bank 1 (actual) 1.000 Lambda Control Bank 1 (specified) Bin. Bits Bin. Bits Block 001, 115 and 118:- Address 01: Engine (06A 906 032 DK) 10:39:06 Group 001: General 2920 /min Engine Speed (G28) 92.0C Coolant Temperature (G62) -1.6 % Lambda Control Bank 1 01101001 Basic Setting Requirements 10:39:06 Group 115: Boost Pressure Control 2920 /min Engine Speed (G28) 18.0 % Engine Load 990.0 mbar Boost Pressure (specified) 1010.0 mbar Boost Pressure (actual) 10:39:06 Group 118: Boost Pressure Control 2920 /min Engine Speed (G28) 29.0C Intake Air Temperature (G42) 0.0 % Wastegate (N75) Duty Cycle 1010.0 mbar Boost Pressure (actual)
this is'nt the log I was hoping to see. more like this will show stuff as an example Code: Group A: '003 Group B: '020 Group C: '115 Engine Speed Mass Air Flow Throttle Valve Angle Ignition Timing Retardation Timing Retardation Timing Retardation Timing Retardation Engine Speed Engine Load Boost Pressure Boost Pressure TIME (G28) (G70) Timing Angle TIME Cylinder 1 Cylinder 2 Cylinder 3 Cylinder 4 TIME (G28) (specified) (actual) STAMP /min g/s % BTDC STAMP KW KW KW KW STAMP /min % mbar mbar 218.45 1800 36.75 100 12.8 218.75 0 0 0 0 219.05 1800 107.5 1780 1400 219.35 1920 41.97 100 6.8 219.65 0 0 0 0 219.96 2240 126.3 2170 1610 220.26 2360 72.08 100 6 220.56 3 3 0 0 220.86 2680 175.2 2360 2190 221.16 2920 109.92 100 3.8 221.47 3 3 0 3 221.77 3280 191.7 2300 2520 222.07 3440 118.94 100 3.8 222.38 3 3 0 3 222.67 3560 183.5 2270 2350 222.97 3680 128.69 100 2.3 223.28 3 3 0 3 223.58 3920 183.5 2310 2330 223.9 4080 138.39 100 6.8 224.18 2.3 3 0 3 224.48 4320 178.2 2290 2260 224.78 4440 146.67 100 4.5 225.09 2.3 3 3 3 225.39 4680 174.4 2260 2180 225.69 4800 155.53 100 6.8 226 2.3 2.3 3 3 226.29 5040 165.4 2230 2080 226.59 5120 159.72 100 8.3 226.92 1.5 2.3 3 2.3 227.21 5400 158.6 2190 2000 227.5 5520 166.25 100 9 227.8 1.5 2.3 3 2.3 228.11 5720 154.9 2180 1960 228.41 5840 168.89 100 10.5 228.72 1.5 5.3 3 2.3 229.02 6080 147.4 2140 1890 229.31 6160 171.61 100 10.5 229.62 1.5 5.3 3 2.3 229.93 6400 142.1 2150 1850 230.22 6480 172.94 100 12.8 230.53 1.5 4.5 2.3 5.3 230.83 6720 135.3 2140 1830 231.13 6800 173.64 100 12.8 231.43 1.5 4.5 5.3 5.3 231.73 7040 130.8 2130 1830 232.03 7120 175.69 100 13.5 232.34 0.8 4.5 5.3 5.3 232.64 7240 127.8 1190 1810
you log it in vagcom choose your datablocks to log and press log, give it a filename an it creates a csv text file which xl opens.. www.ross-tech.com for how to do this
Mine flicks the occasional 1,maybe 2. Its on +2.25deg and if I add .75 then I see 3s. I did log changes on gtech but can't remember it all now, but if you add .75 and its pulling an additional 2deg then surely you're no better off?
Tried doing that but didnt work followed all instructions too, any ideas anyone ? Examples of what evryone has got and how to do it, thanks
Logs Code: Logs are as follows Badger5: Group A: '001 Group B: '115 Group C: '118 Engine Speed Coolant Lambda Control Basic Setting Engine Speed Engine Load Boost Pressure Boost Pressure Engine Speed Intake Air Wastegate (N75) Boost Pressure TIME (G28) Temperature (G62) Bank 1 Requirements TIME (G28) (specified) (actual) TIME (G28) Temperature (G42) Duty Cycle (actual) STAMP /min C % STAMP /min % mbar mbar STAMP /min C % mbar 0.31 1560 66 -3.9 1101010 0.6 1560 49.6 1000 1080 0.9 1600 21 0 1070 1.21 1640 66 7.8 1101010 1.51 1680 51.9 1000 1070 1.81 1720 20 0 1070 2.11 1800 66 13.3 1101010 2.41 1840 65.4 1080 1140 2.71 1920 20 1.2 1190 3.02 2000 66 4.7 1101000 3.32 2120 99.2 2050 1300 3.62 2240 20 80.8 1440 3.92 2360 66 0 1100000 4.22 2520 154.1 2120 1840 4.52 2680 20 73.7 2100 4.83 2880 66 -8.6 1101000 5.13 3080 182 2120 2380 5.43 3240 21 55.3 2150 5.73 3400 66 -13.3 1101000 6.03 3560 164.7 2010 2010 6.33 3720 21 56.9 2070 6.64 3880 66 -12.5 1101000 6.94 4040 155.6 2060 1990 7.24 4200 23 61.6 2050 7.54 4320 66 -4.7 1101000 7.84 4520 151.1 2020 1990 8.14 4640 24 62 1980 8.45 4840 66 1.6 1101000 8.75 4920 145.1 1990 1960 9.06 5080 27 62.7 1950 9.35 5200 66 0 1101000 9.66 5320 137.6 1940 1890 9.96 5440 30 64.3 1870 10.27 5560 67 3.1 1101000 10.56 5680 132.3 1900 1850 10.87 5800 32 66.7 1840 11.17 5920 67 3.1 1101000 11.46 6040 127.1 1860 1830 11.77 6160 35 70.2 1820 12.08 6240 67 4.7 1101000 12.38 6360 121.1 1840 1800 12.68 6400 37 75.3 1800 12.98 6480 67 2.3 1100000 13.28 6520 118.8 1830 1800 13.57 6680 39 76.1 1800 13.89 6680 68 2.3 1100000 14.19 6800 119.5 1760 1810 14.49 6840 43 0 1820 14.79 6880 69 2.3 1100000 15.09 6840 48.1 1000 1370 15.4 6840 39 0 1250 Next lot: Group A: '001 Group B: '002 Group C: '031 Engine Speed Coolant Lambda Control Basic Setting Engine Speed Engine Load Injection Timing Mass Air Flow Lambda Control Lambda Control Bin. Bits Bin. Bits TIME (G28) Temperature (G62) Bank 1 Requirements TIME (G28) (G70) TIME Bank 1 (actual) Bank 1 (specified) STAMP /min C % STAMP /min % ms g/s STAMP 0.31 1720 86 -2.3 1101011 0.61 1800 93.2 10.88 33.89 0.03 1 1 1.21 2000 86 -10.2 1101001 1.51 2120 121.1 13.6 53.42 0.91 0.93 0.945 2.11 2360 86 -14.8 1101001 2.41 2520 168.4 17.68 86.69 1.81 0.922 0.945 3.02 2840 85 -11.7 1101001 3.32 3040 166.2 20.06 109.28 2.72 0.953 0.945 3.92 3360 86 -9.4 1101001 4.22 3560 166.9 20.06 113.53 3.62 0.844 0.945 4.83 3880 85 -10.2 1101001 5.13 4040 163.2 19.38 121.03 4.53 0.836 0.875 5.74 4360 85 -7.8 1101001 6.04 4520 154.9 19.04 134.31 5.43 0.867 0.867 6.64 4800 85 -2.3 1101001 6.94 5000 146.6 20.06 140.17 6.34 0.867 0.86 7.54 5200 85 -0.8 1100001 7.85 5360 138.3 20.06 141.53 7.25 0.789 0.797 8.46 5600 85 -0.8 1100001 8.76 5720 132.3 19.72 144.36 8.16 0.774 0.766 9.36 5960 84 -0.8 1100001 9.66 6080 126.3 18.7 147.25 9.05 0.774 0.766 10.27 6280 84 0 1100001 10.57 6400 121.1 18.02 148.22 9.97 0.797 0.766 11.18 6600 84 0 1100001 11.47 6680 115.8 17.68 147.47 10.87 0.766 0.766 12.08 6800 84 0 1100001 12.38 6840 92.5 13.94 114.14 11.77 0.75 0.727 12.98 6840 83 0 1100001 13.29 6800 30.1 4.08 40.78 12.68 0.75
wrap Code: around the text and it will be readable slash code at the end, not table [code]Group A: '001 Group B: '115 Group C: '118 Engine Speed Coolant Lambda Control Basic Setting Engine Speed Engine Load Boost Pressure Boost Pressure Engine Speed Intake Air Wastegate (N75) Boost Pressure TIME (G28) Temperature (G62) Bank 1 Requirements TIME (G28) (specified) (actual) TIME (G28) Temperature (G42) Duty Cycle (actual) STAMP /min C % STAMP /min % mbar mbar STAMP /min C % mbar 0.31 1560 66 -3.9 1101010 0.6 1560 49.6 1000 1080 0.9 1600 21 0 1070 1.21 1640 66 7.8 1101010 1.51 1680 51.9 1000 1070 1.81 1720 20 0 1070 2.11 1800 66 13.3 1101010 2.41 1840 65.4 1080 1140 2.71 1920 20 1.2 1190 3.02 2000 66 4.7 1101000 3.32 2120 99.2 2050 1300 3.62 2240 20 80.8 1440 3.92 2360 66 0 1100000 4.22 2520 154.1 2120 1840 4.52 2680 20 73.7 2100 4.83 2880 66 -8.6 1101000 5.13 3080 182 2120 2380 5.43 3240 21 55.3 2150 5.73 3400 66 -13.3 1101000 6.03 3560 164.7 2010 2010 6.33 3720 21 56.9 2070 6.64 3880 66 -12.5 1101000 6.94 4040 155.6 2060 1990 7.24 4200 23 61.6 2050 7.54 4320 66 -4.7 1101000 7.84 4520 151.1 2020 1990 8.14 4640 24 62 1980 8.45 4840 66 1.6 1101000 8.75 4920 145.1 1990 1960 9.06 5080 27 62.7 1950 9.35 5200 66 0 1101000 9.66 5320 137.6 1940 1890 9.96 5440 30 64.3 1870 10.27 5560 67 3.1 1101000 10.56 5680 132.3 1900 1850 10.87 5800 32 66.7 1840 11.17 5920 67 3.1 1101000 11.46 6040 127.1 1860 1830 11.77 6160 35 70.2 1820 12.08 6240 67 4.7 1101000 12.38 6360 121.1 1840 1800 12.68 6400 37 75.3 1800 12.98 6480 67 2.3 1100000 13.28 6520 118.8 1830 1800 13.57 6680 39 76.1 1800 13.89 6680 68 2.3 1100000 14.19 6800 119.5 1760 1810 14.49 6840 43 0 1820 14.79 6880 69 2.3 1100000 15.09 6840 48.1 1000 1370 15.4 6840 39 0 1250 Next lot: Code: Group A: '001 Group B: '002 Group C: '031 Engine Speed Coolant Lambda Control Basic Setting Engine Speed Engine Load Injection Timing Mass Air Flow Lambda Control Lambda Control Bin. Bits Bin. Bits TIME (G28) Temperature (G62) Bank 1 Requirements TIME (G28) (G70) TIME Bank 1 (actual) Bank 1 (specified) STAMP /min C % STAMP /min % ms g/s STAMP 0.31 1720 86 -2.3 1101011 0.61 1800 93.2 10.88 33.89 0.03 1 1 1.21 2000 86 -10.2 1101001 1.51 2120 121.1 13.6 53.42 0.91 0.93 0.945 2.11 2360 86 -14.8 1101001 2.41 2520 168.4 17.68 86.69 1.81 0.922 0.945 3.02 2840 85 -11.7 1101001 3.32 3040 166.2 20.06 109.28 2.72 0.953 0.945 3.92 3360 86 -9.4 1101001 4.22 3560 166.9 20.06 113.53 3.62 0.844 0.945 4.83 3880 85 -10.2 1101001 5.13 4040 163.2 19.38 121.03 4.53 0.836 0.875 5.74 4360 85 -7.8 1101001 6.04 4520 154.9 19.04 134.31 5.43 0.867 0.867 6.64 4800 85 -2.3 1101001 6.94 5000 146.6 20.06 140.17 6.34 0.867 0.86 7.54 5200 85 -0.8 1100001 7.85 5360 138.3 20.06 141.53 7.25 0.789 0.797 8.46 5600 85 -0.8 1100001 8.76 5720 132.3 19.72 144.36 8.16 0.774 0.766 9.36 5960 84 -0.8 1100001 9.66 6080 126.3 18.7 147.25 9.05 0.774 0.766 10.27 6280 84 0 1100001 10.57 6400 121.1 18.02 148.22 9.97 0.797 0.766 11.18 6600 84 0 1100001 11.47 6680 115.8 17.68 147.47 10.87 0.766 0.766 12.08 6800 84 0 1100001 12.38 6840 92.5 13.94 114.14 11.77 0.75 0.727 12.98 6840 83 0 1100001 13.29 6800 30.1 4.08 40.78 12.68 0.75
