I've got this alloy cage for my battery. Whats the best way to mount it? Just drill 4 holes in the cage & 4 holes in the floor & bolt it down? Obviously i want it to be safe
It would be better inside the wheel base and as low as possible, the rear passenger foot well is ideal
hmmm, that would mean using less cable and i like that I still have carpet in that area though and for the moment, original seats on runners
I have mine behind the pass seat. Is that for a full size battery? Have a measure up to see if it will fit. You want to make sure the battery isn't sat direct on the bolt heads - a piece of wood can solve that. Ideally you want to be able to get the seat out without pulling battery and tray. Is the car still a daily? If not, carpet is heavy, although so are standard seats and mounts.
What cable are you going to use? I've been looking myself, the norm seems to be 135amp? From what I've seen anyway.
Mine came out of an Audi 200 Quattro - had to cut it down and put a new end on it. A lot of BMWs and Mercs also have long, thick cables to rear mounted batteries.
Standard battery so its pretty big. Got 4 meters of 4awg battery cable. I read alot of people saying you have to use 0awg, but the people that i've spoke to using 4awg havn't had any problems. BMWs don't use 0awg and they have longer than 4 meters to the back
Ok, not enough room behind passenger seat Would it be better in the spare wheel well, or on the left flat area?
Hmmmm - inside the wheelbase is better. Don't much like either of those though. Is there enough legroom in the pass footwell to put it in there maybe? I'm assuming you're using a sealed, and ideally a gel battery, to avoid any possible acid leaks.
Back into the engine bay now. Looks like the positive battery lead comes off the battery & splits. Big cable goes to starter motor & small blue cable goes to alternator. Hmm, do i have to split my new power cable?
Get a distribution block, your new cable goes into one end and the other will have 2 or more connection points
Yep you can do that. I left the original battery leads in place, and put the positive one inside a waterproof junction box ( cost 2 or 3 quid - used for ponds and outside lights) so if I ever need to reconnect a battery in the original place (e.g. as a get me home fix) then I've still got all the cables there. I just connected the new +ve cable to the original clamp, which takes care of starter and alternator connections.
You can get full size sealed batteries too - Torque Starters were one brand from years ago. It's unlikely to happen, but if you have a big smash or a roll, you could have sulphuric acid flying around in the cabin.
