Hey guys, I'm doing a twin carb valver and yet to buy a manifold but I'm interested to know peoples experiences and opinions on what you think is best and where's the best place to buy and best prices! Any help is appreciated
TWM is a good manifold, almost all tuners in holland in the autocross run them, on ITB and carbs. JMR inlet manifold is designed to be the least flow restricted, so maybe even better!
Has anyone any experience of this manifold? http://www.ebay.co.uk/itm/GOLF-1-8-...arts_Vehicles_CarParts_SM&hash=item4ab9e742fe Does anyone know if the JMR manifold comes with a fitting kit?
I'm sure Mr Hillclimber would sort you out with a proven product, tested on his trusty flow bench. Just so you have other options, I've heard good things about Rowland manifolds too, but you'll probably have to import them from South Africa.
cheers for the help guys, i'm just researching what's out there at the moment so I don't want to waste Mr.Hillclimbers time just yet until I know it is the one for me
JMR fitted on mine, noticeable difference over previous short runner cast manifold, highly recommended
bike carbs have individual vacuum tappings per runner. always liked that. makes balancing a breeze, if you have a quad bike carb balancing setup just a thought Jon
Might I be so bold as to hijack this and ask what manifold this is? I was planning to use it for my abf on twin webers, but it needs a bit of fiddling with first as the allen bolts don't quite fit when you're doing them up. I need to grind some material out for a bit more clearance around a few of the holes. Should I ebay this one and get one from mr hillclimber is the next question...
Angle doesn't look as drastic as some of the cheaper mangolesti manifolds, but cracking work all the same. Crackle black always looks great, copper trumpets are lovely too. Are they also homemade?
