Bosch TPS 'click' is it WOT - Now with Pics
Discussion in 'Throttle bodies & non-OEM ECUs' started by drunkenalan, Sep 8, 2008.
  1. drunkenalan Paid Member Paid Member
    Leicester
    I have a Bosch TPS for my megasquirt conversion, i has a click at one side, am i correct in assuming its a WOT marker?
  2. drunkenalan Paid Member Paid Member
    Leicester
  3. Trev16v
    Oxfordshireland
    I would actually ask whether it really is a TPS that you have.
    Bosch also made units that look like a TPS, but are in fact sealed units that simply have two switches inside. One for closed throttle, one for WOT. You can hear the switches clicking inside.
    When I was searching the local scrapyard for a TPS, all of the Bosch units I found turned out to be as described above. In the end, the only TPS units I could find were Ford.
    Can you post a picture of what you have?
    Trev
    apparently rover k-serires engines have a tps that works with ms and fits on a MK2 throttle nice using a bracket, must be tons o rovers appearing in the scrappy now, but be quick before they rust away :lol:
  5. drunkenalan Paid Member Paid Member
    Leicester
    its from a vauxhall, ill take a pic and put it up later, it only clicks at one end of its movement.
  6. drunkenalan Paid Member Paid Member
    Leicester
    its a temporary bracket before you start!
  7. EZ_Pete
    EZ_Pete Forum Junkie
    Under Bonnet, nr Abingdon
    Some discussion here.
    Not sure how helpful it is, but I just googled the Bosch PN and got loads of results.
  8. Trev16v
    Oxfordshireland
    That is very much like the units that I origially got hold of, and discovered that they weren't TPS units, but just a couple of switches inside (as opposed to a potentiometer).
    Edit: I suppose that either could be called a 'TPS' coming to think of it, but for MS you require a potentiometer type.
    Just simply use a DVM on resistance setting between the centre terminal and one of the outer ones; you'll quickly tell!
  9. Ess Three Forum Member
    Aberdeenshire, UK.
    How about an ABF TPS?
    The spindle size looks to be roughly the same...and they work perfectly with MS.
  10. drunkenalan Paid Member Paid Member
    Leicester
    ok tried it out last night with a Fluke, the left pin and central pin have a circuit regardles of position, the resistance changes as i open the throttle.
    So it may be a Potentiometer???
    Ess Three, got one for sale?
  11. Ess Three Forum Member
    Aberdeenshire, UK.
    I'll have to check, but I think I have a couple spare, in my toolbox.
    Won't be back onshore for a week though...so it would have to be after that.
  12. drunkenalan Paid Member Paid Member
    Leicester
    only a week or so, the car is still in millions of pieces so im in no rush! let me know when your back and we can sort something out!
