Hi, I'm replacing all the brake pipes that run from the master cylinder on my mk2 golf but need a tool to produce the tight bends as the pipes enter the master cylinder, does anyone have any idea where I can get one to do the job. I got one form sealey tools but it won't produce a small enough radius. Thanks E
Try carefukkly using your thumb and something round thats roughly the same diameter, thats what I do when I dont use the bender.
can you get a flexible mandrel (like a small, stiff spring) down the tube to support it when you bend it? if you don't then there's always the risk that a tight bend will put a kink/crease in the pipe.
You can put brake pipes into tight bends without needing an tools just use your fingers and do it by hand.
