How much should the brake pressure regulator unit be adjusted when you drop the suspension? Dropped the golf approx 50mm and adjusted the brake pressure regulator about halfway along the adjustable section. Will this be fine or will I see my ass over taking me on a wet round about?
no need for wet roundabouts to see ur own ass infront of you! i managed it in the dry! i havent done mine yet as im still asking around the same question... seems to be adjust and hope for the best answers at the moment.
yes you should, the way ive always done it is to slacken the adjuster and set it so the slack is just taken out of the spring with car sat on level ground. been driving the gti for at least 3 years set like that and ive never had an loose **** moment when braking. well, at least due to the rears locking up anyway
