Breaker Bar pickle
Discussion in 'Tools, Equipment & Fasteners' started by onnie, Sep 15, 2010.
  1. onnie Forum Member
    Romford, UK.
    I need to change my mk2 golfs outer driveshaft gaitor.
    I need a breaker bar, so halfords sell a 3/4" breaker bar but not 3/4" 30mm sockets to fit it. How dumb is that?!
    Eurocarparts sell 3/4" sockets and bars, even 1" ones but I have to wait 3-5 days for delivery!
    Where the hell can I get a breaker bar of decent length (min 60cm) with a socket to match, for tomorrow?
    Thanks.
  2. BristolFish
    BristolFish Forum Member
    5129'6.21"N 212'53.61"W
  3. turbotommy Forum Member
    Newcastle upon tyne
    Whats wrong with a 1/2" breaker & socket? i've done "loads" of driveshaft nuts with mine with no problems,i use a multi-sided socket too!
  4. MK1-Tron
    MK1-Tron Forum Member
    Staffordshire
    Same as Turbotommy 600mm 1/2 drive Britool, done loads and not had any problems.
  5. danster Forum Addict
    Unless it is a seriously good 1/2 breaker bar they will tend to break when you get a real tight one.
  6. Matt82
    Matt82 Forum Addict
    GTI Scene
    i own a half machine mart breaker. it has done hub nuts with 4ft of exhaust for leverage
    it also did the 29mm crank bolt on the 928. 290nm or something daft and i had to undo it. the breaker bent maybe 30* but still survived
  7. madmonkey Forum Addict
    Nordwest
    I've also got a Machine Mart 1/2 breaker, it's surprisingly good quality.
  8. onnie Forum Member
    Romford, UK.
    thanks mate, there's one not far from me!
    I've had a few 1/2" sockets snap on me before so I try to get more beefy stuff now.
  9. turbotommy Forum Member
    Newcastle upon tyne
    Fair enough if you've had a few sockets break on you,i have seen a bar break its pin too.
    Having said that,if you were to buy a 1/2" bar & 30mm socket from Halfords and it broke on the nut 1st try,i'd march back & ask to see the manager and have a word.Its a nut torqued to well under 200 lbs-ft (supposedly)
    I've done over 20 on mk2 to mk4 golfs with mine so far.
    Good tools do cost mind so i understand only wanting to buy once.(mine are cheap so i can't complain if they break)
  10. 2dubnick Forum Junkie
    Worcester
    Iv broken a machine mart breaker bar undoing a hub nut but I did have 5ft of scaffold pole on it and I went and bought another identical one and its been fine for loads of different hub nuts on different cars, it was a pug 806 that killed my old one.
  11. m1keh Forum Member
    Halfords proffesional with lifetime warranty ;).
  12. Mike_H Forum Addict
    For the OP - you can get 3/4 to 1/2" adaptors that'll do the job.
    I've got a 1/2" draper expert bar, which seems fine with 14 stone of me standing on it [:D]
  13. MarcN Forum Member
    Reading Berkshire
    +1 from me. Used mine to do lots of hub nuts, never let me down.
  14. Matt82
    Matt82 Forum Addict
    GTI Scene
  15. onnie Forum Member
    Romford, UK.
    After phoning around mobile mechanics, some were too busy and some didn't pick their phone up. I tried with my 1/2 socket set and it seemed OK with me bouncing up and down on it so I've caved in and just reserved the halfords 24" 1/2 bar. Gonna go and pick it up now.
    Cheers for all the replies :)
  16. onnie Forum Member
    Romford, UK.
    whey hey, one bounce and it came undone!
    Cheers fellas!
  17. Jaundice
    Jaundice Forum Member
    at home
    I snapped a 1/2" halfords breaker bar undoing a hub nut on my old golf, but then used a Halfords pro 1/2" ratchet and a 4 foot scaff tube to undo the nut with ease and without damaging the ratchet[:s]
    I took the broken bar back to halfords though and they swapped it for a new one[:D]
  18. rocco2litre
    rocco2litre Forum Junkie
    go and get 4 foot scaffold pole....will undo any nut
  19. rubjonny
    they do sell a 30mm socket to fit their breaker bars, i think you need some new glasses ;)
    tip: look for 6 point 'impact' sockets ;)
  20. onnie Forum Member
    Romford, UK.
    I was on about the 3/4" drive sockets, they don't do 30mm ones.. I already had a 1/2" 30mm one so that was cool.
    Used the bar to do it back up today. It made the job really easy, thanks again chaps. :)
