where can i get on from, been told there around 30 quid...... wanna get one asap!!!! fed up of paying 20 quid every few months!!!
so that works the same then, do you have to get the car sat on flat ground on 4 axelstands to do it? because any slope in the ground will contribute to a **** up....
you need the car on flat ground whatever tool you use to check it best way is to check the reading with the wheels on the ground , then say for example its 1 deg out...jack it up and put it on a stand and take another reading on the disc and then ajust it 1 deg from there
I'm curious about this too - having to pay every time I do anything affecting wheel alignment is bloody costly.
im gonna go buy a digi spiritlevel now, any tips on which ones to get, i have serious pos camber on my dropped golf!!!
You might end up needing to change the bolts to the slimmer ones if it's that bad, 100mm is one hell of a drop.
mite go 4 this baby, and at 18quid!!!! http://www.twosrus.co.uk/product_info.php?products_id=169 edit:70quid!!!!!![:^(]
i got whatever was cheapest on ebay the hardest part is finding flat ground to check it....i believe some people shim up some plywood so its flat..then park on that
i'm lucky that my garahge floor is flat.... - i park car in square on, then mark round wheel position with duct tape on ground (will explain why in a sec) - i then use spirit level with a kinda prong tape to it that goes to lower part of wheel rim - i then measure to the top of the rim with a small ruler (i then work it out into degrees) - then jack up car, remove wheel and adjust - once putting car back on ground i take it for a short drive, then repark in duct tape squares and doubel check it as the tyre won't sit on ground right once its put back on ground (i also set tyre pressures first
yeah tyre pressure has to be a biggie, i will put mine on stands and make it level i think, just buying a tool for 30quid (normally 70!!!!!!!!!!!!!)
you have to check the camber with the wheels on the ground to find out what settings you've got to start with. As soon as you jack the car up the wheels drop and completely change the camber.
^^^like the old dunlop one , expensive arent they? one fell in my lunch bag on the way out of work one night lol
so how do you test the camber with the wheels on the ground then?? put a steel wheel on so the magnetic bit sticks to it cuz it obviously wont stick to a ally
Not hi-jacking this thread. But as I need to get my camber done as the tyres are getting worn badly on the inside, I presume its best to get it done with brand new tyres as the worn tyres would already be worn to the 'in-correct' angle??
I got my camber gauge from here - http://www.justoffbase.co.uk/Magnetic-Camber-Castor-Gauge-Sealey-GA45 And there is a user guide here - http://www.conrod.co.uk/susp.xhtml
