Cleaning Aluminium
Discussion in 'Miscellaneous Technical Queries' started by Dave, Feb 26, 2010.
  1. Dave
    Sligo, Eire
    Going to have a go at cleaning the water pump housing.
    Already tried dilute Wonder Wheels in the ultrasonic tank, this is the result.
    So, it's oven cleaner + dishwasher time.
    Mr Muscle or Betaware Carbon Remover
  2. Dave
    Sligo, Eire
    Mr Muscle applied on the upper surface.
    Carbon Remover on the lower.
    The Carbon Remover is vaery old, 20 years or so. It's gone thick and black and the fumes are aweful.
  3. Dave
    Sligo, Eire
    Out of the dishwasher. Still not clean.
    Back into the Ultrasonic tank with dilute Wonder Wheels.
  4. alexisblades99 Forum Member
    sunny helsinki
    i've used a nicely worn-out wire brush in a drill before, lubricated with some wd40. the aluminium oxide which rubs off gets caught in the oil and acts as a mild abrasive, i did my gearbox like this last summer then washed it and it still hasn't dulled.
    i've tried dishwashering a few ally bits but it seems to make the fusty white stuff rise to the surface for some reason.
  5. Dave
    Sligo, Eire
    Anyone tried this from Frosts?
  6. altern8 Forum Junkie
    Cocos (Keeling) Islands
    I used a wire drill attachment
  7. mk28vICED Forum Member
    Rugby
    a small shot blast gun would beat any product on the market I reckon.
  8. pigbladder Forum Addict
    cambridge , uk
    bet its just wheel cleaner
    degrease it ...wire brush and alight coat of wheel silver makes things look pretty much new
  9. tinydubs
    tinydubs Forum Member
    when its as bad as pictured blast cleaning with acrylic beads would be best.
  10. 2dubnick Forum Junkie
    Worcester
    blasting is what I do for ally bits I want to clean, always come up nice.
  11. Dave
    Sligo, Eire
    I agree completely, regarding bead blasting, but I don't have compresser anymore. I had to leave this, and all my other workshop machines, in the UK when I moved back to Ireland 10 years ago.
    I am not looking for a painted or shiny finish, just clean, even dull aluminium.
    The Frosts AliClean may work as it is 30% phosphric acid, most wheel cleaners I've seen are about 5% Hydrochloric acid:
    Frost Ali-Clean
    Brightens dull or corroded aluminium wheels, castings, and fabrications
    Directions
    Spray onto area to be cleaned. Work in with a stiff nylon bristled brush. Allow a few minutes for Ali-Clean to work, then wash off with water. Heavily soiled or corroded pieces may require several applications.
    Correctly used this product will not affect paintwork and contains no abrasives.
    Avoid use on polished surfaces as this may cause discolouration and streaking.
    Uses
    Specially formulated for cleaning aluminium un-polished Castings, rims, spokes, and fabrications.
    1. IDENTIFICATION OF THE SUBSTANCE / PREPARATION AND OF THE COMPANY / UNDERTAKING
    Product name: ALUMINIUM CLEANER Synonyms: AC
    ALICLEAN
    Use / description of product: Very toxic. Corrosive. Liquid.
    2. COMPOSITION / INFORMATION ON INGREDIENTS
    Ingredient 1: ORTHOPHOSPHORIC ACID 20-35%
    CAS: 7664-38-2 EINECS: 231-633-2 [C] R34;
    3. HAZARDS IDENTIFICATION
    Main hazards: Causes burns.
  12. Supercharged Forum Member
    Or just buy a complete new pump and housing from VW - 25 exchange!
  13. pigbladder Forum Addict
    cambridge , uk
    light coat of paint over cleaned up alloy looks just about like new parts ..doenst shine or look glossy
    i dont think any of these products will bring it up like new tbh
    cant u remove all the ropey bits and take em to a blaster ?
  14. Dave
    Sligo, Eire
    Did not know that an exchange unit was available.
    It's not just the water pump, that was just experimental as I had to put a new pump on the AUDI 100. I want to be able to clean any aluminium at home, at any time. Don't know where the nearest bead blaster is, probably Dublin? Plus, you have the have spare cash to get bead blasting done. I am time rich, cash very poor!
    The housing was off my old PB. Turns out it is a different housing to the Audi anyway. So the Audi one just went back on as it came off. The power steering pump bracket was wire brushed.
  15. Admin Guest
    best degreaser for a gearbox?
    had a go with some gunk/petrol and a brush, then hosed it of, has improved it but its still very filthy.
    whats the most effective way of getting it all off?
  16. Dave
    Sligo, Eire
    With you for degreasing, always use Gunk or Jizer, but it won't take of corrosion.
    Why don't you try this and let us know how good it is:
    I'm not sending for any until you UK lot try it!!:)
  17. Admin Guest
    the box won't be corroded its got to much greasy grime on it:lol:
    Will stick it in the car and take it to the jetwash over the weekend, the boys next door never did do that for me:(
    See what mum has in the cupboard to. something will have to make light work of it, gunk isn't really touching it to well. I want something that cuts through it.. .Cillit bang do anything strong?
  18. Golfamily7 Forum Member
    Tried cleaning my gearbox last weekend with Gunk, absolute rubbish, waste of money.
  19. Admin Guest
    its done nothing but spread the muck about so far
  20. altern8 Forum Junkie
    I used it last weekend on mine and it was ok,got a bit off wire drill attachment and jet wash to finish
    Still dirty
