Converting wheel bolts to studs and nuts
Discussion in 'Track Prep & Tech' started by GVK, Apr 4, 2005.
    Studs posted back in the summer here now spotted in the 2012 Demon Tweeks catalogue :thumbup:
  2. mk1. Forum Junkie
  3. mk1. Forum Junkie
  4. Peter Jones Forum Member
    Australia
    Been working through some front drive flanges today.
    I chose ARP studs part number 100-7719 they're listed for Mazda race applications.
    Wheel Stud Style Press-in
    Wheel Stud Thread Size 12mm x 1.50 RH
    Knurl Diameter (in.) 0.507 in.
    Underhead Length (in) 2.750 in.
    Knurl Length (in) 0.335 in.
    Quick-Start Nose No
    Quantity Sold as a set of 4.
    Notes Designed to fit Mazda front or rear 1990-93 applications
    and front only on 1994-2005 applications.
    The knurl diameter is pretty small and doesn't need a lot of metal taken out. I drilled the threads out to 12.5mm and them reamed the holes to 12.75mm. (After checking with ARP
    Pressing them in is a nice tight fit.
    I made this tool to spot face the back of the flange, it's a bit rough but seems to work OK.
    I'm still figuring out all this machining stuff.
    Here I'm just trimming a little off the inner edge of the stud heads so they don't foul on the hub.
    Nice work Peter. It had never occurred to be that spot facing would be necessary for ARP stud heads pushed through from the back on the front drive flanges. I'd looked at ARP studs a few times and wondered whether to use them.
    Fairly commonplace to spot face on the back of rear discs or drums, and hence so few people do it!
    Hope your build is coming along well.
  6. Peter Jones Forum Member
    Australia
    Did the rear discs. I modified the spot facing tool to reduce the diameter of the cut to the bare minimum.
    Some discs are more suited to this than others depending on the ID of the bell.
    I had to take a small cut into the sides for clearance, for most holes it's about 1-2mm.
    In hindsight maybe a better approach might have been to turn the heads on the studs down a bit.
    The thickness of the sides varies around the disc and from the top to the bottom of the cut.
    I don't think the amount I've had to remove is enough to cause any issues given how little work the backs do and the perhaps overdone thickness of the bell in the first place.
    Anyway, here's a bunch of pictures, I'm pretty pleased with the result.
  7. A.N. Other Banned after significant club disruption Dec 5th 2
    Intricate machining work there.
    Very nicely done :thumbup:
  8. gingernuts Forum Member
    Near Perth, Scotland
    Studs ordered from a guy having them made in another forum (yes there are such things!)
    They are tried and tested on theirrace cars which are far faster than mine, ill let people know what they are like. Only 80 posted to!
  9. gingernuts Forum Member
    The proper specs on these are:
    M12x1.5
    70mm overall length
    EN24T Stud and lightweight nut
    They are dry oil dipped
    The ones ive order are used but as new just to save a bit of money. Looking forward to getting them on this weekend after years of reading this thread and trying to decide what to buy!!
  10. Bruce T Forum Member
    On the bog...
    Would be verrrrrrrry interested in these if you could hook me up?
    These look the best by far, and at that sort of price, not too harsh on my wallet :thumbup:
    Cheers,
    Bruce.
    I bought a selection of 70mm and 90mm, the latter to allow for spacers (total length measurements).
    So 70mm is looking ballpark. These translated to 47mm protrusion.
    PM me to assist with a Group Buy pls. Thanks :)
  12. gingernuts Forum Member
    now fitted my set, great fit and quality. slightly long but no real problem!
  13. RyanMac Forum Member
    Peter would these studs be long enough to fit in a set of 10mm spacers and still secure the wheel safely.....
  14. Peter Jones Forum Member
    Australia
    Was that question directed at me?
    If so then the answer is yes, but that's based on a steel wheel. Alloy wheel have thicker hubs, you'd have to check your specific application.
    Rear studs ended up longer than the front as they don't have as much metal to pass through.
    I can measure the exact length protruding from the hubs if you'd like.
  15. RyanMac Forum Member
    sorry Peter that was directed at you. Can you measure the protruding length and then I can check if they would work on my wheels and spacer arrangement before ordering them.
  16. Peter Jones Forum Member
    Australia
    Sorry Ryan, I've sort of run out of time, I'm off to Amsterdam for 10 days. I'll take a look when I get back to Oz on the 15th.
  17. RyanMac Forum Member
    No problem peter. I have a feeling now after reading another post that they will be M12 being a four stud hub and the vr6 I have will be M14 being 5 stud but when you get back I'll still grab the measurements off you. Have fun in Amsterdam.
  18. Peter Jones Forum Member
    Australia
    Back again,
    Yep, my studs are M12, here's the specs again so you can do the math on the hub thickness.
    I measured them today,
    Fronts have 44mm of thread protruding and protrude 55mm in total.
    Rears have 42mm of thread protruding and protrude 53mm in total.
    The nuts I've chosen are 20mm overall.
    I tried 13 and 15 mm spacers with the the G60 steel wheels and there was still about 4mm of thread left.
    Front with no spacer fitted.
    Front with 13mm spacer.
    Front with 15mm spacer.
    Rear disc total protrusion.
  19. Nige
    Nige Paid Member Paid Member
    I`m running ACS Race series studs :thumbup:
    A proper raised shoulder to securely seat onto the hub
  20. RyanMac Forum Member
    cheers Peter. I'll have a check when I get near the car again.
