how low are you looking to go? I would say 7x15 et25 is probably best suited to you. If you run 7x15 et25 with 195/45 I would say you could get away with a 40mm drop. If you want a 60mm drop, you will need to trim the arches back a little. Edited by: young dub
Nail on the head mate...it does seem that all the so called 'nice cars' have specially adapted hubs or arches. This is about as Low as i'm going...maybe a few more notches on the rear Edited by: Vento Mike
well you need some travel in your suspension - especially on uk roads - and especially with your engine as they say over here "keep her between the hedges"
TH line mono all the way, def one of the coolest wheel on the market, was at styledynmix over the weekend they getting a shipment very shortley! and go for stretched 195 45 15's!
later model cabs,rivages and were an option on mk2's i think? psm sent mike edit:feckinell,just realised theyre 8x15's Edited by: riley
Personally Id go for the rh classics, they look ace. You gona do a wee up date in the members motors section soon Vento Mike? havent heard much from you in a while. Cars looking good.
The compos will fit over 280mm brakes, no sure about the others suggested, 14s definately will not. Have a search on ebay, I picked up a set of 5 compo th, for 150 quid, then sprayed them up my self.
