Hi need some help I am doing an engine conversiob using the ary 1.8t 20v engine and am a littke stuck with the coolant run specifcally the header tank 2 ports what goes where ? Pics and advice needed many thanks james
The bottom header tank hose goes to the outlet on the back of the water pump on that metal pipe , and the bleed off one is the metal pipes that go along the top of the inlet manifold / bolted too it
