Hello Everyone Does Anybody have a Diesel Pulse Adpators ? http://buy1.snapon.com/catalog/item.asp?store=snapon-store&item_ID=78287&group_ID=1318 i need to borrow one to set my injection timing up , only a 1 hour job and i can't justify paying 100+ for one that i only need for a day. if anybody can help it would be much appreciated. Thanks
Well my Pulse Adaptor arrived today . connected it all up LED Flashing to indicate it was sensing Injection Pulse but when i connected the timing light to the pick up loop the timing light didn't flash ? checked timing light on MK1 and it worked fine . any ideas ?
what are you connection it to? What you timing? doesn't a timing light pick up the HT lead, via a inductive coil
Injection Timing for the Mechanical Diesel Injection Pump (12deg Advance) Pulse Adaptor converts the Injector Pulse into a inductive signal the Timing light can pick up Here's the Gunson One i bought. http://www.gunson.co.uk/item.aspx?item=5139&cat=662 http://www.gunson.co.uk/items/pdf/Products/77089_Instructions.pdf
The Crank at TDC Injection pump pulley mark is at the rear ? i thought it should be 180deg round at the front ???? Timing mark at the rear as detailed by plastic pipe , VW manual says it should be at the front. All the pulley's Hopefully i will get hold of a DTI Gauge but may have to buy a Pulse Adaptor to get the timing perfect.
Just spoke to Gunson and its a faulty unit so i need to go through the hassle of sending it back and getting the replacement. Inductive Pick Up that's not working.
