Digi throttle body options?
Discussion in 'Engines' started by Tristan, Jan 2, 2018.
  1. Tristan
    I've a mk2 Digi getting standalone management, the legendary TonyB suggested a 9a t/b so as to have a built in TPS. Is it a direct fit, or easily adapted? Or would any others like KR fit? Obviously I don't want to go bigger if possible on the throttle plate.
    Tia
  2. drunkenalan Paid Member Paid Member
    Leicester
    for my old 8v I removed the top fitting off the digi TB and fitted a TPS and a bracket to hold it still, that worked well once it was setup. I hadn't heard of the 9a option.
    there was an audi TB that fits and looks like it has a TPS fitted, but its actually just a switch for closed throttle and WOT, it doesn't nothing at all in between.
  3. Tristan
    Any pics of your old setup?
  4. mr.brown
    mr.brown Paid Member Paid Member
    Sunny Surrey
    I've got what is either an Audi or Passat Auto throttle body with TPS (a brand new Bosch TPS in fact). It's a direct fit for DX/PB manifold. I will try and dig it out.
  5. Tristan
    Thank you.
  6. drunkenalan Paid Member Paid Member
    Leicester
    just check it is actually a TPS
    the one I had I think was from an ABK engine? a late 2.0 audi 80?
    ill see if I can find a decent picture.
  7. Finite
    Northamptonshire
    This mod is on here somewhere and pictured or at least it was in one of Toyotec's threads. An Audi throttle body, but it still had to be modded with one extra item for Megasquirt iirc.
  8. mr.brown
    Sunny Surrey
    Fitted to a Digi manifold. One of many "future" projects was DX to Megasquirt.
  9. HPR
    HPR Administrator Admin
    Audi 5 Cyl TB is bigger
  10. rubjonny
    the 9a one with TPS is from automatic cars, not so easy to get these days
  11. mr.brown
    Sunny Surrey
    I'm pretty sure that's what mine is - although I bought it in the US so probably from a 3b Passat? [:s]
  12. rubjonny
    yeah i would think americaland is the easiest place to find them these days, possibly ebay.de might come up with the goods if you can find the right deutche to feed i8nto it
