Hi everyone, This is my first post here, after reading a lot of very detailed chats about my current woes (details to follow). First off I have to say - I do not own a GTI. I own a mk1 LT 31, running a factory Digifant 1 setup, of which there are less than 5 still on the roads (by my count!) I have a few years of history with this beast but I’m too attached to it now to give up. It also seems that there are many many more similarities between g60’s and the mk2 golf than there is with other LT’s so I’m asking here after not having much joy elsewhere despite a great community online for the mk1 LT. So my problem is that there is currently no earth signal being sent to my fuel pump relay from the ecu. I can run earth to the relay from pin 3 of the ECU and run my pumps and ‘jump’ the relay to make the pumps runs but I cannot get the ecu to send earth. I’ve checked my earths but what am I missing? Just had the ecu back after 2 new transistors being soldered on and still won’t work! Look forward to hearing any opinions on this matter
I had a '79 LT, 2.0, so I've a bit of a soft spot for them too. Ex German fire service, turned it into a rally service barge. What fuse box does it use?
Hi Tristan, It’s a CE1 I think, with the 167 fuel pump relay and the 30 digifant relay. The rest is pretty standard and not ecu related. sounds awesome! That would’ve been the 2.0 Porsche 924 petrol engine? my LT is my baby, a lockdown project that has escalated into a huge overlander camper shell with roof extension and lots of bodywork, recon cylinder head, lift kit etc...I’m too far in to go back now !
if its a ce1 it should have a 53 relay in slot 1, 67/80/167 in slot 2. only ce2 uses the 30 relay in slot 3, fuel relay is slot 12
Hi, It did run like this - but no more. It will power the pumps but the engine will not start as it is. I’ve since sent the ECU away for ‘repair’, had it back, and now it won’t run. I used to hear the ISV valve clicking open and closed with ignition on pre crank, but not got this any more either. checking pin to pin at the moment, got the VW wiring diagrams and checked all the earth points, all good...not sure what I’m gonna find here but would like to know the loom is sound
ok that must be an LT specific fusebox then, as the 167 relay cant fit in slot 3 of either the ce1 or ce2 fusebox as the terminals are too big for the socket. pics?
I I shall upload a pic at lunchtime, working from home so can nip in and out. All the relays except the starter relay are in the fusebox (which is in the NS footwell) I’ve got a rusty psych under my fuse box and the remnants of a burnt spade terminal (used to be a minibus so there were extra electrics) but I’ve got rid of all excess now to work out why it won’t start
They’re clipped above the fuse box. The standard fusebox has a line of fuses underneath and one row for relays above; this houses the wiper relay, a relief relay and emergency light relay. I have pics on my phone but can’t upload as I don’t have a URL.
ok maybe the older ceramic type or something similar? covers ce1, ce2 and ceramic, is it any of these: https://clubgti.com/forums/index.php?threads/fusebox-faq.219775/
It’s definitely not the CE2, it’s basically the ce1 83-92 with 2 and 3 for the digifant relay and fuel pump relay respectively
And ceramic type fuses though they are different locations. My fuel pump fuse is in slot 15 for example Hi Nate, I started digging around with this yesterday, actually. does power come to the ecu through pin 1 ? It’s a standard 25 pin harness. All other pins are identified through wiring diagram. Pin 1 is a red wire connecting via 2 connectors to 2 thicker and thinner red / black wires at the fusebox. Guessing that runs to ignition switch but ran out of testing time last night
Oh so this is Digifant 1? Yeah that tell the ECU the car is cranking as I remember, Its not needed though to make the ISV work and pump prime. Should just be ground on 13 and 19 and power on 14
ok thats cleared that up then. so first check does the ecu relay click with ignition on, put your finger on it to see. if not, pull it out and use a jumper wire to link the 2 pins where 30 and 87 of the relay plug into (should be numbered on relay base) see if that does anything for you
Thanks for pointing me in that direction. So as far as my wiring diagram says I am basically feeding the fuel pump relay 12v straight from the ignition switch when I do this. It previously had an issue with its earth at terminal 85 back to pin 3 on the ecu but I’ve repaired and checked the sh*t out of that wire pin to pin and it’s definitely working now lol.
