coil overs are easy to fit! ive only done the back so far, im going to a garage to get the front, fitted tomorro, how much you recon they will charge?! tim
I know, i'm just lazy, it's cold out, and that annoying thing called 'work' keeps threatening to get in the way
yeh i find that to! been out for a more spirited drive today, its sooo different and much more fun! tim
A few questions on the subject... 1) What do you get in the Eibach kit? 2) I assume you get the ARB inner and outer bushes? 3) What about the front Eye Bolt mounting bushes? x4? Also, I'm planning to fit Powerflex Subframe bushes (x4), Powerflex Rear Beam Bushes (x2) and Powerflex Steering Rack mounts (x2 - No PAS). 4) Are there any other bushes/ fixings that are worth changing at the same time? (Excluding Wishbones/ WB Bushes). 5) Are the Dubsport seam welded and Poly bushed wishbones any good? Cheers
