Seen an aftermarket set of alloys advertised in the local rag. Am I correct in thinking that they are also PCD of 100? Is there any reason why these shouldn't fit e.g. ET ? Cheers, Andy
Yes I think they are the same PCD if they are 4 stud. Offset is the only real thing you need to worry about.
The four stud versions of the VW have a 4x100 pcd which is the same as 4 stud VX, some Rover (some are 4x114.3 or 4x96), Honda, Renault and a few others
There's summat nagging away at me at about the centre bore size. I think Rover may be too small but I can't remember If it is, no real prob anyhows.
You can just get them placcy things for the center of the rim, I think they have Vauxall rims have a lower offset so you MAY have to use spacers.
yeah where do you get the placcy trim bits from? how much etc. need some for some other alloys o have.
indeed, the vaux centre bit is 56.5mm, rover are 56 or 56.6 depending on model, vw are 57mm Edited by: 0ddball
Any thing other than genuine wheels and the centre bore shouldn`t be a problem, most ar 60mm or more and use spigot rings to fit different hubs.
Damn, such a nice car too, unlike the Austin heap 'o' shoite This is not nice though Edited by: madmonkey
