Hi there everyone I am just fitting up my new Motec M1 ecu and need some info on wiring if possible I have an Audi TT pedal 0 280 752 234 and I am looking what each wire does 1. White/blue 2. Yellow/geeen 3. Gray/red 4. Grayblue 5. Gray/white 6. Brown/blue Also when I am here I have the R32 throttle body wired up but need to know only 2 wires 5. Brown/violet oem118 +12v or -12v 3. Black/violet oem 117 +12v or -12v These are to power the motor Thanks Aaron
Have a look at our STC wiring diagram, page 5. That should give you what you need. http://www.dtafast.co.uk/download_files/Wiring_Diagrams/STC Wiring Diagram.pdf
Thanks very much for that... On the throttle body you have pin 3 as motor 1 and pin 5 as motor 2... should one be 12v and one be GND Thanks Aaron.. Ps are you still looking my R32 pin out
No problem No. The ECU will switch the 12v and ground around to move the butterfly whichever way it needs to go. Not sure which way round they go on the MoTeC. Yes please.
