Should you get any movement from in / out iv taken the drive shaft off the hub and gave it a tug it gives about an inch to an inch an a half of play? Is this normal ? Cheers
Another way to describe it is with the driveshaft all in place and done up if I grab the shaft I can push and pull it about an inch of play is this foobard or should there be a bit of play? HELP
