How hard is it to fit eibach anti roll barsto a mk1 golf i think i know how to fit them but i wanted to be first to post here
Yeah same as Std, Make sure you get some new wishbone clamps for the front ones as they have a habbit of sheering off when you try to undo them.
haven't done anything with the ARB's on the rocco, but I remember the polo ones being a bit of a bugger, as you had to pre-load them before/while fitting, are the rocco/mk1 ones similar, in that they are under load when fitted?
A set of Eibach ones are just over 200 notes. Just noticed Volks-Speed do a lightweight adjustable rear one for 190.
i got mine from venom 205 + postage how hard are the rear ones to fit too can i use standard arb clamps for the front i got the rear ones in the kit and all the polly bushes and a small thing of greese shall i use this or sumit else
I found the rear one a lot easier to fit than the front one. The standard clamps fit fine on the front, it's only the bushes which are different, they have a larger centre diameter to accomodate the larger bar. I never used any lube on mine and they don't squeak, or maybe I just can't hear them squeak over all the rattles and squeaks coming from the inside of the car!
i got them fitted but the passengers side clamp did not hold it in properly as if the holes in the wish bones were too far down gona try a new clamp today
I had to jack up one side then support it and then jack up the other wheel so it doesn't hang down so low to make the wishbones more even. I guess it depends how stiff your car is already but they made my car much more fun to drive
who sell the new clamps do you know ? the polly bush on the passenger side has poped off because it wasnt holding it on properly i havent pushed it much but it seems like its gona be fun
I think I got the wishbone clamps from GSF. I needed to replace one of the inner clamps too which I got from the main dealer.
Does it only effect cornering? I have koni kit dampner adjustable, front top & bottom & rear top struts, eibach arb kit... etc But the car still wants to fly off the road when i plant the power under heavy lock (front wheel drive quirks?)
i havent had a chance of really testing it yet because the clamps i just bought new ones yestorday from vag 4 each so all being well i will find out today
