Hi all. A while back i did a gearbox change and the car wouldnt pull away without the engine juddering violently. I discovered that the gearbox needed lifting a tad and it solved the problem. The issue i have now is if i change down a gear and lift the clutch the engine/clutch or something judders badly. I can stop it doing it by giving the car a little throttle. But im not a rally driver and cannot heal brake, so cannot always do it. Does anyone have any ideas? Could it be a naf g/box mount as i brought a GSF one only a few months back. thanks (shes a mk2 8v GTi)
