Hi Wound any of these mounts work for a 20vt swap, so it doesn’t hit master cylinder and sits correctly in bay. I have a mk2 with a mk3 subframe and these mounts for the current agg engine 1ho 199 354k 1ho 199 273a 1ho 199 353d Thanks in advance
1H0199354K - MK3 1.8-2.0 8v 020 rear 1H0199273A - MK3 1.8-2.0 8v 020 front 1H0199353D - MK3 1.8-2.0 8v 020 gearbox so a full set of incorrect what you need is: 357199353A - 02A gearbox 1H0199354B -> 1H0199354H - MK3 02A rear you can get away with the rear if you fit a 10mm spacer between it and the block, but its not like the 02A rears are hard to get Edit: Sorry forgot it was for a MK2 with MK3 subframe. So for the front if you have a corrado VR6 front engine carrier, you use the MK3 bracket 1H0199273B. If you still have the MK2 front carrier you need the corrado/passat/g60 one 357199273
Would mk3 vr6 gearbox mount be any good? No part number on listing sorry. Or seat Ibiza Cupra mounts all round any good? Again no part number on listing sorry
Yeah vr6 box mount is ok, it's the same as the abf/TDI and also same as used on g60/corrado/Passat etc The seat 20v rear will do you fine as well. front is same as mk3 so only works with corrado vr6 type front engine carrier
