Ifve installed it including the cracks and the hardlock but i'm still getting hardlock error Anyone got any ideas what i'm not doing to get this working??
yeah, bad file name or something like that i think...... Is that causing me the problem then do you think???
i've got etka 5 it worked fine on windows ME but now that i've installed XP it doesn't work. i know there's away around it but can't remember what to do, does anyone know ???
Just change the screen resolution so it's larger than the screen actually supports - then you can scroll around it as Keith says.
<bump> No joy getting ETKA 6 or newer so thought i'd bump this up. I'm sure there must be someone that knows how to get 5.6 working on XP............... Please help someone [:^(]
This happened to me! Have you applyed the crack yet? I fogot to do this and it cleared the error for me
This is how i done it. installing etka on nt4/2000/xp RUN :\etkasetup(where D is your cd drive letter) choose thelanguage and instalation required install the zipserve programme when prompted DO NOT ATTEMPT to run the etka program copy following files from the folder d:service (where d is your cd drive) ncz_w_di5505.exe ncz_w_sel5505.exe ncz_wine5505.exe into the etka root directory on the hard\ disk (default is c:\et_prog) select all files in folderC:\ET_PROG andset their attributes to not be "read only" inthe following folderC:\ET_PROG rename the following files.... W_DIENST.EXE W_SELECT.EXE WINETKA.EXE to be something along the lines of.... W_DIENST.NT4 W_SELECT.NT4 WINETKA.NT4 then from the ET_PROG.W95 folder on the cd copy the following files.. W_DIENST.EXE W_SELECT.EXE WINETKA.EXE to the C:\ET_PROG folder run the patch files... NCZ_W_DI5505.EXE NCZ_W_SEL5505.EXE NCZ_WINE5505.EXE in the C:\ET_PROG folder this for running version 5 I never touched the hardlock I think once you done that it's all over . Oplaii
