Could anyone with etka kindly help me by checking the part numbers for the rear abs speed sensor rotors(these basically go into the back of the rear discs. Also the part number for the right hand abs speed sensor for the front. The car is a 1990 golf g60 edition 1. All help greatly appreciated.
I've had a look for you and it seems that the front sensors are the same for either side, as are the rotors on the rear. Here are the numbers I found. Rotor for speed sensor (rear): 191 614 149 Speed sensor (front): 191 927 807 A Let me know if you need any more info. I can email you some screen shots if you want to be more certain.
