Hi, Mk1 Gti 1.6 engine prefix EG Engine number suggests manufactured in 1979 Problem with fast tick-over - 2,500 rpm. Engine does slow down when the air from the auxiliary air valve is restricted but nowhere near slow enough. I think that the problem may be with the 'plumbing'. There appeared to be a Heath Robinson modification made to the air supply which I have removed. I have attached two photographs. Photograph 1 shows the cut off rubber connection from the auxiliary air valve to the manifold and the single connection to the manifold. Am I correct in thinking that these two should connect? Photograph 2 shows another connection to the manifold that was connected to the connections in photograph 1 by a home made 'T' piece. If the two positions in photograph one are connected where does the one in photograph 2 go? Any assistance very much appreciated.
Hi, Thank you for that It runs fast when hot or cold. If I restrict the pipe from the aux air valve it does slow down quite a bit Cheers
