mike took these pics while tommy was setting up my car the other week, cheers mike Edited by: velly_16v_cab
What makes are the throttle linkage and manifold? In fact, tell us all the kit you're using - pump, pressure reg, filters, etc etc... Cheers
ok dude, its a LP-1000 weber linkage facet fuel pump filter/regulater (not sure of the name...ill have to check) the manifold was new but i had it with the carbs, filters....err.....none at the mo, should be getting some socks on friday but i will be moving the rad to make more room
Very nice mate Did you have trouble with the water pipe under the inlet manifold? Also I hope you've got that very shinney throttle set-up adjusted properly as those carb spindles are about as strong as twiglets!
yes that hose was a mother!!! i think they r set up ok, fingers crossed they dont break!!!!! i'll have to measure the pipes tomorrow, im not sure on there size
Hi Velly, How did you deal with the inlet manifold water jacket supply? The reason I ask is a mate has a Audi 80 that we have to shove a set of twin Dellortos on - we have absolutlely everything we need but he just needs to get off his ass!! Go figure? Anywayz I had our machine shop boys lathe up a threaded bypass adaptor but did you do the same or just blank it off?
i never fitted the carbs, Jodie from Dubvelopments did it. i could pass on his number if you want it, he is VERY helpful
There is'nt an inlet manifold water jacket supply. Outlet pipe between cyl 2 and 3 tho. ABF outlset pipe is downward pointing and off to the side. Can help aid manifold clearance. Bill
Now i gotta hear them on saturday on the way to the TSR meeting , just dont forget which way the gear stick goes velly.
cheers 4 that bill, c u on sat. I'll try not to hit 3rd instead of 5th mike...it scared the s**t out of me!
