I have factory AC in my mk2 here in Oz...trouble i am missing a few pipes under the bonnet. since it hasnt had these for a while the compress will be shafted so i am going to get a mk3 set up to. has anyone done this? Ive hit the search button and i know i need the brackets and pulleys...i should pick it up on the weekend so i will start to take it apart next week
mk3 setup should fit fine with some tweaking of the pipes, just need to swap MK2 pressure sensor(s) over and its all good. for the compressor you need: compressor alternator bracket alternator crank pulleys waterpump pulley all mounting bolts & studs If your mk2 has pas you also need: pas pump pas pump brackets all mounting bolts & studs basically strip the block completly bare!
