Hi Anyone know what size bolts are that fasten the clutch pressure plate to the end of the crank ? 16V with rod change box Ta Rob Edited by: RobT
Yep, VW changing the clutch setup doesn't help much here. The mk1/2 setup is "the wrong way round", the pressure plate bolting to the crank with the M10 17mm bolts then the flywheel to the pressure plate with the 12-point bolts which can be undone with a 9mm socket. The 02A box setup (I believe that's what makes the difference here) uses the more common setup of the flywheel bolting to the crank with the M10 bolts and then the pressure plate to the flywheel with the M7 9mm 12-point bolts. Edited by: gregs
LOL- Always causes confusion the "Arse about face clutch" on the 020 set up Anyone know the Part Number of the daft little 9mm headed flywheel bolts whilst we're on the subject? Edited by: G_V_K
Thanks - suspect Ford pinto bolts will work then - can be had in ARP grade for cossie YB's etc so may do the trick - will investigate further. Cheers Rob
Anyone know the Part Number of the daft little 9mm headed flywheel bolts whilst we're on the subject? Yep they are a 12 point socket head screw size: M7x40x20 PART: N100 134 01 9 required
Stock 020 cover to crank bolts are stretch ones are'nt they? Are stretch bolts graded like regular fasteners? like 12.9 for example?
Edit: will confirm the part number for these bolts tomorrow as I need some anyway. Bill, I'm not sure if the pressure plate to crank bolts are stretch bolts as there's no angular torque setting for them, just 74 lb ft. A lot of people do say they're stretch bolts, though. I think it's probably safest to replace them anyway, given the price. They are a 12.9 strength rating. Edited by: gregs
just swapped the 020 2y box in my valver at the weekend and the haynes manual says to ditch the old ones and fit new (ie unstretched) ones when putting it back together...
Those crappy little M7 bolts are a bit sh1te. Think I'll be up grading mine 12.9 when I get round to doing something with the old girl Edited by: Hotgolf
I always presumed they were as they carried the discard when used once tag... Looke dnecked down when I have removed them previously... Don't like em myself.
Given the price I think it's worth replacing them. I have another Haynes which suggests that they only need replacing because they come ready threadlocked but they're cheap anyway. Just to confirm what it says above - the flywheel to pressure plate bolts are: N 100 134 01 M7x1.0, 40mm length Cost me 37p+VAT each, 9 required (although the dealership said that the computer showed them as being required in sets of 6 and in the end they've sold me 10 anyway! ).
