hi all, need some advice on flywheels. can anyone tell me whether or not the flywheel from the mk3 2 litre 16v has the same bolt holes, lugs as the flywheel from the VR6? the holes that im concerned about is the ones that the clutch plate match up to when you bolt that to the flywheel. i know the holes that bolt the flywheel to the actual engine is different, but wasnt too sure on the other ones. just incase you dont have a clue what im talking about, have a look at the pics below. 2 litre 16v/ g60 on the left and VR6 on the right. cheers in advance kenny
