a few quick questions. 1. when undoing this pipe how much fuel is expected to squirt out? -disconnecting with smokers walking past so keen to know what quantites i will be mopping up. 2. fuel is slowly weeping out from the mating point between the fuel feed pipe/metering head clamped together by the securing bolt. This was opened slightly recently to check fuel getting through could this have caused it? if so how to fix? 3 I am correct that there should be no brass washer sandwiched in this join?
1. Very little ... cover the joint with a rag when breaking it - due to the pressure release, can the smokers be rerouted / discouraged ? 2 & 3. Yes - fit a crushable aluminium / copper washer (the weep will probably have dissipated the pressure in the line) I have experienced these joints both with and without washers.
you should have a crush washer ever side of the banjo union the washer should be N 0138128 aye Andrew you see lots of things like that
I think I just needed reassurance. Thinking about it it's only gonna be whats in the pipe from the pump to the metering head isn't it. I'll wait for a risk free moment and bite the bullet now I know it's only a small amount. I dont think there are any copper washers on any of the connectors but will try this if need be. Thanks guys.
