Hey guys.. before i undergo my ABF conversion i want to get my 1300 running as i need to take my daily car off road for some work.. basically the car wont start. there is spark but no fuel gettin into the carb. The guy i got the car from said he was out driving then it died and wouldnt start up again. Is the most likely problem to be the lifter pump in the tank or the fuel pump itself? or even possible the relay? When the ignition is turned on the pump doesn't prime at all.. unless someone's fitted a silent pump .. Also which relay is the fuel one, i have no experiance with mk1's at the moment [:^(]
