Hi, I have a Topran 103 420 fuel pump relay which I now suspect is defective and the root cause of my starting problem. It was bought brand new. Is there any way of bench testing it to be sure? I do know that if I put 12v across it the relay does click in and the two large connectors (from the 12v and to the pump) connect but I do not have any reaction from the relay when the connection from the coil is in place. When the relay is connected the coil connection pin shows 12v. Thanks
