MK1 GTi 1980 1.6 Have replaced fuel pump and all fuel lines New fuel pump relay fitted. Suitable for Mk 1 with external fuse. Problem is the pump runs constantly as soon as the ignition is turned on. Am told pump should only run when engine is being cranked or running. Am unsure of the origin of the fuse box. Came in a box of bits with the car Do I have either the incorrect fuse box or incorrect relay. The fuse box fitted has blade fuses The relay that was fitted was numbered 167 and did not have an external fuse. Most of the wiring had been stripped out when the car was used as a track car Still many electrical problems. Soon as ignition switched on rev counter goes to maximum and stays there Any assistance very much appreciated. Phil
