Fuel pumps and flow capablity
Discussion in 'Engines' started by Toyotec, Apr 14, 2011.
  1. Toyotec
    Model Engine code FPR # & rating FDU # Max est supported power from flow comments
    1G Golf KR/PL N/A 191906091H/J K-JET 128l/hr@5bar maximum flow
    1G Golf PB N/A 191906090 Digifant 2 75l/hr@3bar maximum flow
    1H Golf ABF 3bar 037133035C 1H0919651P Digi 3.0 and 3.2 100l/hr@4bar maximum flow
    1H Golf AAA 4bar 078133534C 1H0919651Q M2.7, 2.9.1 PCM 100l/hr@4bar maximum flow
    1H Golf AAA 3bar 037133035C 1H0919651P M3.8.1 PCM Change occured after August 95 100l/hr@4bar max flow.
    3B Passat ADR/AEB 4bar 078133534C 3B0919051B 115l/hr@3.8 bar maximum flow
    3B3 Passat AWT/ALT 4bar 078133534C 3B0919051C 115l/hr@3.8 bar maximum flow
    1J Golf AGU/AUM 3bar 037133035C 1J0919087H/J/A 115l/hr@3.8 bar maximum flow
    3A Passat AAA 3 bar 037133035C 1H0919651P As per post 95 MK3 Golf VR6 for maximun flow.
    3A Passat AAA 4 bar 078133534C 1H0919651Q As pre Aug 95 MK3 Golf VR6 for maximun flow.
    couple more for you:
    bosch '44
    0 580 254 044 - fuel pump 5bar, 200 l/hr
    Polo GT/G40 NZ,3F,PY - 867 906 091
    0 580 453 918 - fuel pump 3bar, 75 l/hr
    edit: i have some pierburg pump specs if that is any use?
  3. paultownsend Forum Member
    i have a early vr6/aaa 3bar tank/pump to swop from my pb tank/pump set up. im now running abf digi.
    why are they both 3 bar,yet the aaa/vr6 set up had the capability to flow 25L per hour more?
  4. Toyotec
    That tank would be from a later MK3 after August 95, when the engine controls changed. The "3bar" designation is the nominal operating pressure that the system will run on between pump check valve and FPR. The engine will use the required fuel it needs and the rest will be returned to the fuel tank. The maximum flow measurement is done by setting a flow resistance and observing how much fuel volume is deposited in a measuring beaker etc. You can use this information to determine if the pump is capable of delivering fuel to the engine. Using a crude calculator a MK2 Digifant pump is capable of flowing fuel to near 180bhp, where as a VR6 unit can support 280+bhp. During normal operation a PB and AAA engine will only require ~45 and 65 l/hr respectively.
  5. turbotommy Forum Member
    Newcastle upon tyne
    Toyotec,Any idea what a BHP a mk3 ABF in tank pump will support @ 3bar and at 4 bar if its capable?
    Cheer's :-)
  6. turbotommy Forum Member
    Newcastle upon tyne
    So my current mk2 8v pump that flows 75L/hr @3 bar can support 180 bhp and an ABF can support 280bhp+ @100l/hr @4 bar,what can it do at 3 bar then? as i run a 3 bar FPR!!!
