garage lighting
Discussion in 'Garages, workshops & DIY' started by CovGTi, Aug 3, 2013.
  1. CovGTi Forum Member
    Coventry
    Hi
    Got a gargage with no access to power but need some lighting.
    Any ideas?
  2. TSR 2.1 Forum Member
    Scotland
    12v LED would be my suggestion.
    Then you would just need to take a spare car batt with you and power it that way.
    I have a load of 240v LED lights in my garage even the 10w ones are really good. And one of these makes a brill inspection light and no worry about dropping it and the bulb going pop.
  3. TSR 2.1 Forum Member
    Scotland
  4. CovGTi Forum Member
    Coventry
    Cheers buddy
  5. Finite
    Northamptonshire
    What sort of use are you looking for with the light? I bought an advanced headlight from Halfords clearance at 3 and although it was the last turkey in the shop the aluminum cased 1W Cree led is amazingly bright and should last a considerable time on 3x800mAh Ni-MH AAA.
    It would make a good supplement/backup in any case as you'll need a fully charged car battery to last an equivalent time on a 24W.
  6. nealey Forum Junkie
    I've got a petzl head torch that I normally use
  7. 1990
    1990 Paid Member Paid Member
    Rochdale, Lancs
    Whats the roof made of? You could fit a clear corrigated panel.
  8. drunkenalan Paid Member Paid Member
    Leicester
    12v solar panel, a big car battery and the above mentioned LED lights!
    we put a A3 size solar panel on the front of the garage to charge the batteries on the Audis thro the winter, worked a treat til someone damaged the panel with a football.
