My gearbox mount (at the back, right hand side of the engine) is in a right state, and needs changing. Never having done one before, can anyone tell me if it's much trouble to change?
what car u got mate? mine was changed and it wasnt that much hassle, as long as you got the tools. Edited by: Dave
No but one from gsf has a slightly larger diameter. It just makes it a bit harder to slide in. All u need to do is loosen the fron and under the back 1 then jack the box up. Hope that helps
i found it helped to whip of the exp tank..then undo the gearbox bit that it bolts to..its only 3 bolts,easy job with a trolley jack
did mine on my 8v, only took about 1hr to do! not much hassle at all, the old 1 was proper mashed, had split, grease everywhere!
Cheers all - I'll see you all at the pearly gates. Free tickets for all. Now if anyone can diagnose my problem further down the page, I'll supply all the nubile young virgins you can handle. Deal?
